05-23-2011 05:58 PM
Hello All,
Everytime I run the Simple IO - Top Level.vi, it loads the last run sequence file. How do I default it to certain sequence?
Great appreciate for your help.
-Kenny
05-24-2011 02:26 AM
You can use the open sequence file method on the application manager (then you only need to wire the file path)
05-24-2011 02:55 PM
You might also need to set ApplicationMgr.ReloadSequenceFilesOnStart to ReloadFile_None before the call to ApplicationMgr.Start
05-27-2011 04:09 PM
thanks
