‎08-12-2013 02:38 PM - edited ‎08-12-2013 02:40 PM
Hello ,
I am new to NI teststand.
From one sequence file(file1.seq) , i have called another sequence file (file2.seq) , to which i have passed parameter value by reference(Locals.Driver)
Parameter is Local container with string variables.
In file2 , i want to overwrite the value of Locals.Driver.
But i am not able to access passed reference variable (Locals.Driver) in file2.
Please tell me how to use this variable in file2.
Solved! Go to Solution.
‎08-12-2013 06:40 PM
Parameters are accessed by using "Parameters.variable". If you pass by reference, you just set this parameter and it will update the local you used to call the sequence when the sequence is complete.
‎08-14-2013 04:29 AM
Thanks for helping.
