NI TestStand
delete subproperty forever
Hello
I'm trying to delete all parameters of a sequence in run time within LabVIEW using the TS API method DeleteNthSubProperty with index=-1. It deletes all the parameters, but they are away forever... Is it possible to do it only in run-time? After the execution I would like to have the original parameters.
Madottati
(3,502 Views)
Hi....
consider the attached example.
To open the files you need the Version TS2012 and LV2012SP1.
best regards
Bernhard
(3,481 Views)
two times the sequnce files. Sry.
Now here are the vi
(3,479 Views)
