NI TestStand
custom conditions
I have a power supply measurement step in TS 4.2 using LV Adapter.  If the test fails the next step is a popup telling the operator of the possible cause ( Check Power Supply 1 is on).  No problem setting that up in Preconditions.  Now how do you get the sequence to terminate??  Wanted something like: If the check power supply 1 step fails then terminate.  How do you know where the pass/fail result is for a previous step??  I don't want to use the subscript in case I add more steps later.  I read the values for step 1 are stored in a variable with subscript [0] step 2 [1] etc.
Message 1 of 17
(4,121 Views)
Accepted by clint100
I don't have TestStand with me right now, but I'm sure it is the PreviousStep.Result container.  I don't remember the last part at the top of my head.  The autofill should help out as you type it.
GCentral
Message 2 of 17
(4,120 Views)
Nice..thanks.
Message 3 of 17
(4,116 Views)
You can get the status of any previously run step.An example for a step named label is shown below :
if(RunState.Sequence.Main["Label"].Result.Status == "Failed")
{ popup message
go to end
From the expression edit - select runstate then sequence then main then the step you want then results and finally status
Message 4 of 17
(4,108 Views)
Thanks as well.
Message 5 of 17
(4,105 Views)
Is there some generic expression i can use to always get the "previous step"??  I have hundreds of test and if they fail I want the popup to be displayed.  If I cut and paste them by the time I get to the 2 nd test its still linked to the first test.
ie:
Test 1
popup if test 1 fails
test 2
popup if test 2 fails.
etc
if I cut and paste the popup for test 2 I have to go in..delete the precondition statement then add the new one for test 2.
This is an example of what  is there:
RunState.Sequence.Main["ID#:FjhX/Kw9sEqBsghxs7PIsB"].Result.Status =="Failed"
The["id#:f ........ i'm guessing is refereeing to the previous step.  Why is that so cryptic?
Message 6 of 17
(4,096 Views)
Override the SequenceFilePostStepFailure callback and put your dialog in there.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 7 of 17
(4,092 Views)
you can use :
if(RunState.PreviousStep.Result.Status =="Failed")
As for the cryptic thing :
Its the ID of a step stored instead of name.This takes care of somebody accidentally adding new steps or deleting the steps in between , or renaming of a step.
This is optional - whenever you try to link to some step there is a popup which asks you to select ID if required.
Message 8 of 17
(4,084 Views)
Thanks..I think that'll work  !!
Message 9 of 17
(4,076 Views)
Does that ID change everytime you open Teststand ??  I opened Teststand and there is an error on every step I used the
precondition expression:  RunState.Sequence.Main["ID#:FjhX/Kw9sEqBsghxs7PIsB"].Result.Status =="Failed"
  I get   "<FAIL> Invalid Target"
Message 10 of 17
(4,072 Views)
