07-04-2016 07:00 AM
I am trying to create containers of array and in it different containers, which contains some elements with different values.
For that I am using for example Excel file and in it I have create one table, first row is the name of element and second row is value of element and same for third row is also different values.
I want to create sub container in arrays of container like first row should be the element and second row is value and after reading second row its create new container in that again first row should be the element and third row should be the value of elements and same for next row.
here in attachment I tried to do so, but some how I am not able to create separate container as per row change. please guide me how to solve this problem
Thank you very much in advance.
Ankit.
Solved! Go to Solution.
07-04-2016 07:24 AM - edited 07-04-2016 07:24 AM
Hope we have separate Board for TestStand.
07-04-2016 07:38 AM
Is it possible to change the board now?? or do I have to do post again??
07-04-2016 08:50 AM
Hope Your question is something different but accepted solution for different option, which may mislead others, if you found answer by your own you can post the method used and then can accept as a solution
Just My suggestion
07-05-2016 05:22 AM - edited 07-05-2016 05:27 AM
No I havent found the correct solution for it.
And as I have posted this in wrong thred so, I just wanted to delet this post. but somehow I havent found where to delet.
That is why I just mark as solved, so its not bother more.
But anyways here in attachment there is vi, that is atleast able to create the containers of array in teststand.
what I want is to create the array container and in teststand with having subcontainers.
Thanks agin for all help.
