02-26-2016 04:49 AM
Hi All,
After entering or adjusting an expression in teststand, i hit the "check expression for errors" checkmark button. If i made a typo or didnt declare a variable, an error warning pops up, so i can adjust the expression.
Is there a way to check all expressions in a sequence file at once?
An error popup states:
Evaluation Warning
Value invalid or out of range.
If you are certain that the expression will evaluate correctly at run-time, you may ignore the error.
OK
When will the expression evaluation fail at edit time but succeed at run time?
Thanks in advance,
Stef
02-26-2016 05:54 AM
Stef,
the Sequence Analyzer already includes two tests for this:
- Expression error caused by missing dynamic property (Warning)
- Expression must evaluate to a value of the expected type (Error)
Make sure that both options are tested in your Sequence Analyzer project. Run the analyzer and review the report.
Norbert
02-26-2016 06:32 AM
Hi Norbert,
The Sequence Analyzer looks promising. Unfortunately I'm using Teststand 4.1.1. I don't think the "sequence analyzer" is available for this version?
02-26-2016 06:38 AM
The Sequence Analyzer tool was introduced with TestStand 2010. So 4.1.1 does not provide that tool.
Sorry,
Norbert
