calling a sequence in a new thread with different values
I have a sequence that I want to call that runs in parallel (seperate thread). The question I have is that I want to run this sequence from a lot of different places, but with different values of the variables going into the steps inside the sequence.
If I change the values inside the sequence (running on seperate thread), then I will have to duplicate this sequence over and over. What I really want to be able to do is run a step in a seperate thread, and not wait for it to complete. Is this possible? Or a method of passing step values into a seperate thread. I don't want to use globals unless I really have to.
(2,941 Views)
Hi ADL,
I have attached an example which I hope will illustrate an answer to your question.
Regards
Ray Farmer
Regards
Ray Farmer
(2,941 Views)
