NI TestStand
adding to the report
How do you add a popup to TS4 that asks the operator for his clock number ( must store it?) then prints it out ( in the report) at the end of the Test seq??  You'd want to ask for the clock # 1x until the operator logs out.  I'm thinking just before the call to ask for the serial number in Test UUTs.
Clint
Message 1 of 13
(5,115 Views)
Clint,
i'd dock this feature at the user management. You can override the LoginLogout if desired in order to ask for this "clock number". Store the answer in a TestStand variable.
You would then modify the report generation in order to retrieve this data and include it in the report footer.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 13
(5,110 Views)
Hi Norbert,
Thanks.  I looked at the Process Model and can't find the LoginLogout seq??  I guess I don't know how do I do this??
I also don't know how to mod the report gen.  Any help/steps would be helpful.
Clint
Message 3 of 13
(5,085 Views)
Clint,
LoginLogout is not part of the process model since it must be executed outside of any running execution.
The Login and Logout is contained in the FrontEndCallback.seq which can be found in the <TestStand>\components\callbacks\frontend folder.
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(5,078 Views)
Clint,
Probably your best bet would be to use one of the Callback sequence for the Header or Footer (ModifyReportHeader or ModifyReportFooter). There is an example in the examples folder for Modifying the Report Header. Also there is a tutorial in one of the Manuals.
Regards
Ray
Regards
Ray Farmer
Message 5 of 13
(5,073 Views)
So I mod the frontend callback seq to include a popup that asks for the operators clock #.  ( enable response text)  The clock num is stored in step.result.response.  How do I get access to thet value and put it in the report??  Isn't it only live for that callback?
Clint
Message 6 of 13
(5,069 Views)
Clint Eastwood wrote:
[...]The clock num is stored in step.result.response.[...]
Clint,
this is no good. Since you are not in a running execution, keeping the value "clock num" in a runstateproperty is worthless. The most simple thing is storing it into a StationGlobal i guess.
But please note that you should document this in order to know in several years why there is such a StationGlobal and how it is written....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 7 of 13
(5,066 Views)
StationGlobal is really your only option and use the option 0x1 (insertifmissing) so you dont need to worry whether its there or not.
The ideal solution would be to modify the loginlogout.dll to include your clock number so that you only have one dialog.
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 13
(5,062 Views)
So I tried adding the popup in the frontend CB.  I log in but no popup.
Is this getting too complex for DF??
Should I call NI w a SR??
Message 9 of 13
(5,061 Views)
What is DF?
Adding a popup should work. Can you post the modified callback?
Message 10 of 13
(5,038 Views)
