NI TestStand
adding to the report
DF is discussion Forum.
I ended up calling National.  Apparently you have to set a condition on the LoginLogout seq something like "!Loginout".  If you don't it only runs one of the dll in that frontend call back.  I had initally tried the "If the login dll was executed then run the popup".(click on the popup>Properties Tab> Expressions>preconditions> expression builder)  So far the !logout condition works the other doesn't and don't know why.  Now I'm trying to get the step.results.response back into my report.  Going to use sation or file globals.
Message 11 of 13
(1,219 Views)
Clint,
Try this example. If you are using TS4.X then you can reduce the steps by putting the activeX action the expression of the MessagePopup.
Regards
Ray Farmer
Regards
Ray Farmer
Message 12 of 13
(1,213 Views)
Thanks!
Message 13 of 13
(1,200 Views)
