06-08-2011 10:47 AM
I had to downgrade to TestStand 1.0.1 due to tester configuration and after uninstalling TS 3.1 I installed 1.0.1 and now it will not start. I receive the following error: An error occurred in the 'Login' step of the 'LoginLogout' sequence in 'FrontEndCallbacks.Seq'. Unknown error. User defined error code. Error Code; -2147287038.
06-09-2011 09:32 AM
Kendrick,
What OS are you trying to install TS 1.0.1 on? Because of its age, it may not be compatible with XP/vista/7.
Kyle Mozdzyn
Applications Engineering
06-09-2011 09:41 AM
Hello Kyle,
Thanks for resonding!
I have successfully installed on a couple of XP machines. This one is also XP, but the computer is newer.
I tried uninstalling all National products then completely cleaning out the registry of all remnants of National Instruments, Labview, Teststand and even a couple of seqedit references. Then reinstall, same error.
THANKS
Kendrick
06-09-2011 10:12 AM
Have you tried running the version switcher (it probably doesn't come with 1.0.1, but does come with 3.1)? Also what do you mean exactly with login error code? Is this a runtime error? Are there any more details in the error message?
-Doug
06-09-2011 10:33 AM
Yep, no version switcher in 1.0.1.
It happens when I launch the sequence editor.
Never gets to the login pop-up. (see attachment)
Does that error code (-2147287038) mean anything?
Kendrick
06-10-2011 09:35 AM - edited 06-10-2011 09:38 AM
I meant that if you install a newer version of TestStand, then the version switcher it installs should allow you to version switch to 1.0.1.
It's not a TestStand error code. It's from the OS. An unexpected error is happening in that dll. Did you try deleting everything in the 1.0.1 directory before re-installing? Visual Studio says that that error code means "%1 could not be found. ". It might be some system or runtime dlls that are missing.
-Doug
06-10-2011 10:27 AM
I'm not surprised that it is pointing to the OS.
Could it be security?
These computers are locked down pretty tight, although I do have administrator rights.
Does TS need to write to a file first that might be in a protected location on my computer?
I'll try re-installing 3.1 and see if I can switch to 1.0.1.
I've tried un-installing, deleting everything, cleaning the registry...
THANKS
Kendrick
