John -
It appears that the difference between the two paths is the failing one has a space in one of the directory name segments. I tried both
C:\temp\temp longname\test.bat
and
C:\temp\templongname\test.bat
and both worked fine for TestStand 1.0.2 and 2.0.1.
Can you add PAUSE commands and ECHO ON commands to the batch file to see if it running and if so where it is failing?
Scott Richardson
Scott Richardson
https://testeract.com
