NI TestStand
Why can't a new serial number be displayed as plus a new serial number control in indicate mode like original one in PUUTPANEL ?
 In parallel mode TestStand runs paralleluutdlg.c file other than uutdlg.c file. In sequence mode Teststand runs uutdlg. It can be directly modified for plus any input serial_box in CVI, its easy and no any questions.
But in parallel mode, Its big different process way. At first Teststand calls Initialize Dialog function as fig 3 in the attached file. This init function creates a child panel which gets all attributions such as ATTR_FRAME_STYLE,width,scroll,left.right, UUT_SERIAL_NUM_LBL so on forth (fig4) from PUUTPANEL automatically. The control of SERIAL_NUM (fig5) is not a normal hot mode other than a indicate mode,(it only displays and can't be get serial number from this control). It calls PUUT_SerialNumCallback(Fig6).   So new controls are displayed on the several new child panels dynamically which depends on the number of sockets in parallel mode.  It is complicated process way in parallel mode.
Up to now I can't find any codes to shape new serial number control in new child panel and which codes can get serial number in these codes.  So if plus a new serial number control in indicate mode like original one in PUUTPANEL (FIG1), it can’t be displayed (Fig2).  That is my question.
Message 1 of 1
(1,829 Views)
