Where is the .NET String Class in the .NET Adapter?
In .NET, the String class has lots of handy methods like .Split, .Join, etc.  So I thought I'd add a .NET Adapter step, point it to the mscorlib(2.0.0.0) in the GAC, and use the System.String class.  However, I can not locate it in the Class: pulldown on the adapter settings.
Am I missing something here?
(3,869 Views)
Accepted by Richard.Morgan
Current versions of TestStand do not show the basic types (e.g. System.String, System.Int32, etc.) from mscorlib in the .NET adapter and do not support directly calling the members of System.String. This will likely be addressed in a future version of TestStand. In the meantime, you will need to create an assembly which wraps the functionality you need if you wish to use the methods of System.String.
-Doug
(3,865 Views)
Richard -
I encourage you to sign up for the TestStand 2010 Beta. There are some exciting new features in the .NET Adapter coming down the pipeline. It would be most helpful to us to have .NET users start experimenting with these changes and report back any issues or additional suggestions.
David Rohacek
(3,839 Views)
