NI TestStand
When will SequenceFilePostResults Callback called?
I am wondering, when the SequenceFilePostResults callback will be called.
I created a simple sequence just to fill up the ResultList[] array. There must be a treshold, when TestStand triggers the callback, but it doesn't occur.
Attached you can find the sequence file (made in TS 2014 32 bit), where a message popup should appear, when the callback is triggered.
(1,177 Views)
This callback seems to be working only if you activate on-the-fly reporting.
Yet the NI documentation
https://www.ni.com/docs/de-DE/bundle/teststand/page/list-of-engine-callbacks.html
https://www.ni.com/docs/de-DE/bundle/teststand/page/caveats-for-using-engine-callbacks.html
does not really describe this IMHO
(1,162 Views)
Accepted by Madottati
PostResults gets called when On the Fly result processing is turned on. It gets called depending on the thresholds you set in the advanced button of the Result Processing dialog:
(1,127 Views)
Yes, that is exactly what I needed. By the way I set these properties through activeX nodes, see attached sequence file
(1,111 Views)
