NI TestStand
What are the available different types of Parameters
My sequence sorts through a different selected sequence for prototypes that haven't been updated,  it updates them and may enter a value for that parameter.  I'm trying to discover what the type is of that parameter dynamically, to display to the user.  For VI calls and for Sequence Calls the types are returned as a number.  What is the corresponding number?
DOOJ
(3,097 Views)
Accepted by PhoenixCall
In the TestStand help type Type in the index tab.  Then select the adapter for which you want to look at the parameter types for.  For example if you want to look at the Sequence Adapter Types choose SequenceCallParameter.  Then it should show you the "enum" types.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,095 Views)
That worked wonderfully, thanks.  Can't forget to use the help!!!
(3,045 Views)
Step.Module.AsSequenceCallModule.Parameters.Item(x).PropertyObjectType.ValueType
This will yield what is in the ValueType Property in the TS Help and is accurate unlike the obsolete Type for SequenceCallParameter.Type.
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,037 Views)
Ah, yes that works very good now.  A great many thanks.
(3,034 Views)
