 VaibhavKanchan
			VaibhavKanchan
			01-17-2012 06:30 AM
Hello All Big Guns,
Vector OpenTest, tests are modeled in a graphic notation based on UML. Test-specific elements are added to the options in the UML state diagrams. This gives test designers a form of modeling that is adapted to the domains of ECU testing.
This OpenTest supports the test automation systems, CANoe from Vector and TestStand from National Instruments.
Do the National Instruments is having something which supports NI TestStand and CANoe from Vector?
My customer requirement is to create sequences using TestStand which can peform the same task in vector CANoe too....
Your comments will be imortant for us....
Regards-
Vaibhav
 RayFarmer
			RayFarmer
			01-17-2012 11:33 AM - edited 01-17-2012 11:39 AM
Well Vector do a LabVIEW CAN driver, therefore you could write TestStand sequences which use these LabVIEW dirver VI (or probably code modules which call these CAN driver VIs).
[This OpenTest supports the test automation systems, CANoe from Vector and TestStand from National Instruments]
Not sure what this statement implies (I read this from there e-catalogue) maybe you should ask Vector.
 RayFarmer
			RayFarmer
			01-17-2012 11:51 AM - edited 01-17-2012 11:52 AM
Looking at the Vector OpenTest information, it suggest there is a generator built-in which will generate NI TestStand sequence/SequenceFile.
 j_dodek
			j_dodek
			01-18-2012 12:30 AM
I am using CANoe in TestStand. But i never used OpenTest.
Maybe i do not understand the question about the requeriements.
Do you like to transform your openTest code to NI-TestStand
or should TestStand Sequences just control and manage CANoe from scratch?
Juergen
