'Value' is a reserved name in TestStand...Why?
'Value' is a reserved name in TestStand, which means that you cannot create a variable/object in TestStand named 'value'. It's seems like a benign thing but to me it is an unecessary limitation. So why is that and are there any other reserved words that I need to be aware of?
Q: Why is it a problem for me?
A: my application is built to dynamically react to messages on a vehicle network, and I have no control over message definitions or the software architecture of our system. It just happens that at least one (that I know of) message has a parameter named value, since it is a pretty common word.
(3,390 Views)
It is reserved for historical reasons. There was a feature that used it in a very early version of TestStand. The feature was obsoleted, but the name had to remain reserved to preserve compatibility with any sequences that might have used the feature.
(3,387 Views)
Freak,
This is very common to see certain keywords reserved in programming languages and in that regard TestStand is no different. I don't have a list of reserved words off-hand, but how are you getting your values before you do something with them? Would it be possible to just add "myVal_" to the begining of all of your values comming into TestStand, and take it off going out of TestStand. That way you would be working with "myVal_Value" rather than "Value". Using this technique, it wouldn't matter what the reserved words are. So how are you getting the values, and storing them in a way that causes an exception in TestStand?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,356 Views)
