what programming environment are you using?
You have the MAX Viewer activeX control available, so you can embed that in a program that will then act as a means of selecting the items (by hand). The MAX viewer will allow you access to the item names, but no further - i.e. you can't directly get information on the setup of items (channel counts etc) but you can retrieve the information that is shown in the MAX tree control.
Hope that helps
I have an example I'm working on in LabVIEW so I know it's possible, but unfortunately I can't attach it as yet (work in progress etc)
S.
// it takes almost no time to rate an answer
