Showing results forĀ
Search instead forĀ
Did you mean:Ā
User Manager Window problem
I'm logged ti TestStand as administrator but the "User Manager" window is dilled i can't acess.
Can you help me please
TestStand 13.0
Message 1 of 12
(6,479 Views)
I assume that "dilled" is mistyped "dimmed".
Are you using the NI Sequence Editor?
Did you, by accident, altered the user rights of your administrator in the past?
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(6,475 Views)
Sorry yes is dilled,
Yes i use the sequence editor
I don't remember if i altered the user rights of my administrator in the past
Message 3 of 12
(6,469 Views)
Do you have another system installed with TS which works as expected?
If so, copy the users.ini file from the working system over to the non-working. The users.ini is in the TS config directory (by default in ProgramData).
Norbert
EDIT: "dilled" is no english word. That's why i asked... replying "Yes, it is dilled" doesn't really answer my assumption....
Norbert
Expert: Geometry
Message 4 of 12
(6,454 Views)
I did this 3 days ago, the some thing, it work in the other system but not in mine
Message 5 of 12
(6,445 Views)
Did you overwrite the correct file? Did you perhaps by chance alter the cfg directory in your system (Station Options >> Preferences)?
Norbert
Norbert
Expert: Geometry
Message 6 of 12
(6,442 Views)
Yes is the correct file and in the correct path of cfg directory, i tried all this
Message 7 of 12
(6,437 Views)
Medkac,
What do you mean by dilled?
Carmen C.
Message 8 of 12
(6,431 Views)
1) You can delete the user.ini file and it should get re-created with the defaults when teststand starts up.
2) If you are still having problems, please explain exactly what's happening and what's not working.
-Doug
Message 9 of 12
(6,429 Views)
- I deleted the user.ini and restart --> The same problem
- I unistalled the TS completly but nothing changes
This picture explain what i talking about, i'm logged as administrator
Message 10 of 12
(6,420 Views)
