‎05-27-2010 08:59 AM
A have a VI that is called dozens of times from TestStand and it's prototype has changed. Must I visit every step where it is called and reload the prototype?
thanx,
jvh
Solved! Go to Solution.
‎05-27-2010 09:06 AM - last edited on ‎09-25-2018 10:36 AM by Kristi_Martinez
Community Admin Note: The article link has been removed due to invalid information.
If you are not using a custom step type then,
the above link my help you.
regards
Ray Farmer
‎05-27-2010 10:10 AM
‎02-04-2011 03:50 AM
I like that, works very well and saves lengthy 'click & repeats'!
‎11-03-2015 03:47 AM
‎03-23-2022 07:59 AM
Well this is a rather old topic (~13 years old), but I'm having the same problem. I inherited a sequence in which a particular VI has called gazillion times and after modifying the VI now I'm supposed to find all the instances. I see that there were a solution posted which is recently (~5 years ago:)) has been removed.
So I guess this topic goes back to square one... how this can I update the prototype of a given VI everywhere its called?
thx!
