Update Input/Output Parameters from a file
I am new to TestStand and am trying to get together a proof of concept for my management team.  I have one sequence file with two actions that I need to run multiple times.  Each iteration I need to change the input parameters and the limits expected value.  Is there a way to load some sort of file, txt, xml, ect that can hold these parameters.  That way when my requirements change I do not have to go in and change my values around?
BR
(2,972 Views)
There's a step type called Property Loader.  This is likely the guy you want to use.
(2,970 Views)
