キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Update All Types' Versions in Type Palette
Does anyone have a quick way to update the versions of multiple types in a type palette?  I can change them one by one in the Types editor, but that's very tedious when I've got 50+ types.
I'm working on a set of custom step types that we are distributing in a type palette.  For content management purposes, it would be nice to have all of our custom step types and our custom data types have the same version.
I could save my type palette as INI or XML format and do a search and replace, but that's a cludge. I'm sure I could write a small sequence using the TestStand API to do this, but wanted to see if anyone else has had to do it before to save myself some time.
I'm also open to being convinced that this is a bad idea if someone can give a compelling reason.
Josh W.
Certified TestStand Architect
Formerly blue
メッセージ1/4
4,285件の閲覧回数
Create dummy types with the correct version and use the type differ to merge? Though that's probably no better than either of the two things you suggested.
CTA, CLA, MTFBWY
0 件の賞賛
メッセージ2/4
4,275件の閲覧回数
Hi Josh,
I am also looking for the same thing. I found something, but it is not the perfect solution.
1. Have the names of all the step types in the palette file. You can put them in an array variable in a sequence, or read from a file.
2. Use the RunState.Engine.GetTypeDefinition("<TypeName>") and store the resulting object reference in a local variable 'TypeDef'
3. Use Locals.TypeDef.AsPropertyObject.TypeVersion = "<NewVersion>" to set the new version.
THe reason I say it is not perfect is that I would like to somehow get the type names from a type palette file automatically. I haven't been able to figure that out. Any help will be great!
Cheers,
Aditya
TestStand 4.2.1
LabVIEW 2009 SP1
0 件の賞賛
メッセージ3/4
4,142件の閲覧回数
Found it!!
The attached file will
1. Show you all the type palettes you currently have on your station and ask you to choose the one you want to update
2. Ask for the new type version
3. Update all types with new type version (apart from the ones which are from NI like Substeps)
4. Increments palette file change count
5. Prompts user to save palette file
Thanks to @dug9000 for the help.
Cheers,
Aditya
TestStand 4.2.1
LabVIEW2009 SP1
@Changi wrote:
Hi Josh,
Cheers,
Aditya
TestStand 4.2.1
LabVIEW 2009 SP1
メッセージ4/4
4,131件の閲覧回数
