Unload Sequence
How can I unload sequence after it finished running?
In unload option I picked the unload after step executes, in MainSequence I did not set Optimize Non Reeantrant calls to This Sequence, but still the used memory did not decreased.
Thanks.
Message 1 of 20
(5,577 Views)
There is an API function that does this.
RunState.Engine.UnloadAllModules()
Glenn Ellis
Message 2 of 20
(5,559 Views)
Sorry I misread your question.  The UnloadAllModuals() function wouldn't be the best solution for you.
I believe you want to unload that individual step.
There is an option in the step settings under run options.  I will look at it when I am at my computer tomarrow to see if I can give you a better answer.
Glenn Ellis
Message 3 of 20
(5,555 Views)
Thanks for the answer, but I need to run different sequences one after another (in one execution).
After one sequence finished running I want to unload it and to run the next one. The configurations I descibed in the first question should be enough, but still it did not work.
Message 4 of 20
(5,555 Views)
1. Select Step:
2. Here is what you need to do to dynamically load sequence.
3. Then  Unload after step executes:
Glenn Ellis
Message 5 of 20
(5,540 Views)
The UnloadAllModuals() would work if you put it in the post Expression on each seq call.  But there is a performance hit if you were to use it after each step.
Glenn Ellis
Message 6 of 20
(5,534 Views)
As I mentioned before, I did all of the properties you suggested (load dynamicaly too), but still not working.
Correct me if I am wrong, but if it was working, the memory that TestStand using suppose to decrease.
I do not use the UnloadAllModules(), only the properties of the sequence.
Message 7 of 20
(5,526 Views)
Can you give an example of what you are trying to do and maybe I can more fully understand what you are trying to do.
Glenn Ellis
Message 8 of 20
(5,512 Views)
Here is an example.
I have sequence with all the properties you said. After the sequence ends I excpect the memory of TestStand to decrees (Task Maneger).
Message 9 of 20
(5,496 Views)
Providing there is no other reference to that Sequence File in you Sequence then I would say your assumption is correct.
Regards
Ray Farmer
Regards
Ray Farmer
Message 10 of 20
(5,492 Views)
