03-21-2025 07:06 AM
I have a subVI that activates a DAQ, and I do it dynamically (Please see picture attached).
The problem is that the first time I run the teststand program, the first time I call that subVI, it takes a very long time.
Is there a way to make it faster?
Thanks so much in advance,
Solved! Go to Solution.
03-21-2025 07:18 AM
The call setup for your TestStand step looks good.
Do you observe this effect also when running the VI directly from LabVIEW with no TestStand involved?
03-24-2025 02:51 AM
Hello Oli,
thanks for your response. I've been testing it separately, and it seems the problem is directly with Subvi, not TestStand. I'll move the question to the LabView forum. Sorry for the inconvenience.
Thanks again for your help!!
