NI TestStand
TestStand RunTime engine 32 bits
I have TestStand in 64-bit and I use Labview's Subvis in 32-bit, so I have the adapter configured as 32-bit "Use active 32-bit Version" (see attached photo Labview_AdapterConfigurator.png).
The problem is if I try to run these subvis as run time engine (see attached picture advanceSettings.png), I get an error "does not match the bitness/version of the LabVIEW Runtime Engine."
I've also tried setting the adapter to "Auto detect using VI version," but it doesn't work.
Is there any way to do this?
Thanks in advance
(636 Views)
(620 Views)
Hello ee-jallen,
yes, i have the same configuration as in the article with the 32-bit Version selected.
But when I´m trying to use the "Always Run VI In LabVIEW Run-Time Engine" it says that does not match the bitness/version of the LabVIEW Runtime Engine.
Should I change the subvi to 64-bit if I want to use it as runtime? is it not possible with the 32 bits?
(615 Views)
