10-24-2025 02:54 AM
I made TestStand - User Interface LabVIEW. I built an application and created an Installer for it. I have installed that setup file on the Other computer to run the executable file. I can open that executable file but I got an error.
I can not understand this error Correctly.
Do I also need Teststand License to run the sequence. Or Run-Time engine is enough for it?
Right now I am using Labview Version: 2024 Q1 (64 bit)
Teststand Version: 2023 Q4 (64 -bit)
Please Guide me though it.
10-24-2025 02:59 AM
Looks like on "the other computer" either the TestStand Runtime (aka Base Deployment License" is not installed or in the wrong bitness.
10-24-2025 03:27 AM
Thank you for the Reply,
Yes, the same Doubt I have.
Question: Do I need the Base Deployment License to run it? I haven't activated it yet.
Can I do with a License key?- Sorry for the Question. But this is my first time using TestStand.
10-24-2025 04:19 AM
Yes,you need the license
I guess you have the NI License Manager installed on your machine, IIRC you can use it to register it with the license key.
11-13-2025 03:30 AM
@megumi98 wrote:
LabVIEW affords the same capabilities essentially, plus much more for people who are capable of writing the appropriate code. TestStand just makes the effort easier and more approachable for a more specific purpose.
How does this refer to the original licensing topic?
