Teststand- labview User Interface installer
I made TestStand - User Interface LabVIEW. I built an application and created an Installer for it. I have installed that setup file on the Other computer to run the executable file. I can open that executable file but I got an error.
I can not understand this error Correctly.
Do I also need Teststand License to run the sequence. Or Run-Time engine is enough for it?
Right now I am using  Labview Version: 2024 Q1 (64 bit)
Teststand  Version: 2023 Q4  (64 -bit)
Please Guide me though it.
(275 Views)
Looks like on "the other computer" either the TestStand Runtime (aka Base Deployment License" is not installed or in the wrong bitness.
(274 Views)
Thank you for the Reply,
Yes, the same Doubt I have.
Question: Do I need the Base Deployment License to run it? I haven't activated it yet.
Can I do with a License key?- Sorry for the Question. But this is my first time using TestStand.
(258 Views)
Yes,you need the license
I guess you have the NI License Manager installed on your machine, IIRC you can use it to register it with the license key.
(247 Views)
@megumi98 wrote:
LabVIEW affords the same capabilities essentially, plus much more for people who are capable of writing the appropriate code. TestStand just makes the effort easier and more approachable for a more specific purpose.
How does this refer to the original licensing topic?
(172 Views)
