NI TestStand
Teststand insertion palette
How can I implement NI VeriStand in TestStand 2020 insertion palette?
(1,491 Views)
If you have Veristand step types installed then they should show up in the insertion palette.  I'm not as familiar with Veristand but I'm assuming it comes with a set of step types for TestStand.  Once those are installed then it should just show up.
If it's the case that you can install for an older version of TestStand but not 2020 then you may have to copy step types and palettes over to the 2020 TS folder.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,439 Views)
The old add-ons are not supported by NI anymore. Please see Replacement for VeriStand Steps for TestStand link.
Instead of  VeriStand Steps for TestStand now  ASAM XIL Steps for TestStand is used to automate VeriStand from a TestStand sequence.
(1,384 Views)
