Teststand expression, Test() example
This sounds like such a simple question...
But the documentation on Teststand is quite brief.
I cannot find a single example on how to use the Time() function as part of an 'expression' with non default parameters.
I want to store the "timeStanpInSeconds" value (Parameter #6).
Do I have to add a value for every single parameter when I run this function?
(4,332 Views)
Accepted by SetecTestDept
That parameter is not something that the function will return.  It's something you give to the function.  As far as I understand it you can throw a large number in there and it will tell you how many seconds are in the number if the number were converted to a timestamp.  So you should know what that number is before you pass it to the function.
Time(True,0,0,Locals.Seconds,0,Seconds(True))
Time(True,0,0,Locals.Seconds,0,123213211)
jigg
CTA, CLA
testeract.com
(4,292 Views)
A better way to say it is:
Time(True,Locals.Minutes,Locals.Hours,Locals.Seconds, 0, 12341234) will always yield 10:07:19
jigg
CTA, CLA
testeract.com
(4,291 Views)
OK, thanks for that... however the expression text/help (Teststand expression browser) is quite, actually COMPLETELY misleading:
Within the Time menu
Time()     Get the current time
Within it's description
Time()
This function returns the current time
Parameter 1: An optional...
Returns: A string containing the current time in localized format
(4,275 Views)
It will return the current time if you don't put parameters in for parameter 6.
jigg
CTA, CLA
testeract.com
(4,259 Views)
