06-25-2012 05:17 AM
Hello Teststand gurus, currently I'm using teststand version 4.0. I have set the administrator log in password for the past 2 weeks and I forgot the password. Is there any way to reset it? Thanks guys. newbie here.
06-25-2012 07:58 AM
Shut down TestStand
Browse to C:\Program Files\National Instruments\<TestStand> and click the Cfg folder
Delete Users.ini
Restart TestStand
It should re-create the Users.ini file.
WARNING: You will delete any other users for that machine.
06-25-2012 10:55 PM
Thanks Jigg. that helps. it's a good start for me.
cheers,
12-18-2018 07:11 PM
Hi Jigg,
This is an old thread. I hope that you can still read it.
I tried the solution and delete the file "Users.ini". Everything was grayed out when I restarted TestStand 4.2.1 even though a new Users.ini file was automatically created.
12-19-2018 08:29 AM
@sangbui_palpro wrote:
Hi Jigg,
Did you log in as Administrator? When you delete Users.ini file it should be recreated when you start TestStand. When it is recreated it automatically adds an Administrator user with a blank password. You need to log into TestStand as that Administrator.
Hope this helps,
12-19-2018 11:56 AM
Thank you so much for your response. TestStand automatically logged me in as a technician. The previous developers set a password on Developer and Admin privilege and they are not around anymore. Is there anyway that I can reset the password and log in as Admin?
Happy holidays to you and your family.
12-19-2018 01:22 PM
Hi Jigg,
Totally my bad. I didn't log in as Admin and Password = blank after clearing the Users.ini file. It works now. Thanks.
