NI TestStand
Teststand 2016 Deployment utility issue in Windows 10
I've moved my Teststand 2016 / Labview 2016 development from Windows 7 to Windows 10 a while ago. Everything works correctly except the Teststand development utility. I can happily create deployments from the workspace using a Windows 7 PC. If I try to do the same on my Windows 10 PC, it complains about VI's having duplicate names (Error -19035). The problem is that all Windows 7 PCs are being phased out by my IT dept, so I have to get Windows 10 working.
It's the same workspace and tsd file, the only difference is the operating system doing the work. Does anyone have a clue what is going on? How can identical files be fine on Win7 but not on Win10?
(990 Views)
It looks like something is messed up on the machine. There should not be a folder called "SupportVIs" in the below TestStand 2016 (32-bit) folder.
Can you start with a clean machine and see if you can reproduce the issue? If so can you find out when is that folder being created.
Anand Jain
NI
(973 Views)
Hi Anand,
Thanks for the advice. I'll try deleting the folder first and hope that fixes it. If not I'll uninstall Teststand and start again.
Colin.
(963 Views)
