‎12-16-2024 06:53 AM
Well after reinstalling TestStand still got the same issue, i think it's something wrong with the LabView Adapter. I don't know how to uninstall it.
‎12-16-2024 07:45 AM
The LabVIEW Adapter is part of TestStand which manages the LabVIEW Calls via ActiveX,
You could try repairing LabVIEW as well
‎12-17-2024 01:45 AM
Hello, i uninstall labview and reinstall it, still no hope. same problem
‎12-17-2024 04:49 AM - edited ‎12-17-2024 04:49 AM
Clutching at straws....
Can you try the following:
1.) Close LV & TS
2.) Navigate to C:\ProgramData\National Instruments\<TSVersion>\Cfg
3.) Rename Adapters.cfg to something else
4.) Start TestStand
5.) Check again..
This is in case the repair / re-install hasn't removed the adater config properly.... AFAIK TestStand should recreate this file with default values.
Nevertheless.... if you are 100% sure this behaviour is directly linked to the execution of this Python script, you should check its' code!
‎12-17-2024 07:50 AM
Sorry but i don't have Adapters.cfg
‎12-17-2024 08:01 AM
Just saw, that there was a change in config directories when updating from 2014 to 2016...
Is there no adapters.cfg in that particular folder, or isn't there any on your computer?
‎12-17-2024 11:38 PM
There is no adapters settings at all.
‎12-31-2024 01:32 AM
Something to try - Using admin command shell can you try to re-register LV by executing LabVIEW.exe /regserver from the folder in which LabVIEW is installed.
Couple of questions:
1. If you launch LV first and then try to edit a LV step. Does that work?
2. Are you launching the TS SeqEdit as the current user who is logged in or with some other user privilege?
Anand Jain
NI
