04-17-2008 01:32 PM
04-17-2008 01:47 PM
04-17-2008 02:13 PM
Thanks Jigg,
After you emailed I tried insterting entire text RunState.SequenceError.Occurred in to expression, but it still does not work. Than I tried haveing all 3 combined RunState.ErrorReported, RunState.SequenceFailed ,RunState.SequenceError.Occurred from Runstate option under Variable/Properties of Expression Browser. May be I have to use Step Result error instead of Run State Sequence Error?
To give you little bit more idea I have total 10 steps in test stand seq.
1. Power up
2. Data Acquisition for band 1
3. Data Reduction - if it does not have valid input data range from previous step data acquisition than, it generates error if it does than we want to redo step 2. IF it has valid input range No errors, find proper data output , check data output limits and go to next step.
4.Data Acquisition for band II
5. Data Reduction
04-17-2008 05:54 PM
08-04-2012 01:18 AM
Hello ~jiggawax~
Can you please help me on following
1. Is it possible for a particular numeric limit test step - to set "Record result " to False if test is fails and set Record result to True
if test passes. In a Do - While loop doing a numeric limit test for a current , do not want to record result as long as test is failing
and would like to record result if test passes.
2. Do you have any example of setting a costom condition in the "Post actions" of a step.
Vinod
08-04-2012 01:18 AM
Hello ~jiggawax~
Vinod
08-06-2012 09:28 AM - edited 08-06-2012 09:30 AM
You need to set your step to "Ignore Run-time Errors" on the step settings dialog, or it will go to cleanup. Note: I've only read the first post. It's possible the problem has already been determined to be something else, but a likely reason why a post action would not go where you tell it on error is that errors generally cause the flow of execution to go to cleanup.
-Doug
