NI TestStand
TestStand java doesnt display GUI
hello i have a java code that contain a Java native library(API) providing serial communication with a pcb , this library contains dll files (rxtxSerial.dll)
my problem is that testsTand doesnt load the interace where this library is used , i doubt that testStand can't find it or can't read it ,what should i do to fix it ?
thank you
(3,153 Views)
@manel123
Can you please explain what you mean when you say "...testsTand doesnt load the interace where this library is used"?
If you can provide screenshots of the issue you are running into in TestStand, that will be very helpful.
(2,994 Views)
