05-25-2017 06:37 PM
The ModelOptions callback is a great way for example to set the number of sockets in the batch model dynamically.
The issue is that this is set once and for all when the sequence is loaded.
Is there a way to set the number of batch sockets between batches?
I would like for our operators to be able to test 5 units one batch, then 4 the next, ...
05-26-2017 04:35 PM
I've decided that while it would be nicer if TS could handle batch sizes that vary a bunch, I can live with the operator either having to disable slots or with overriding the preBatch.
05-30-2017 03:06 PM
Hi there,
When you're talking about setting the number of sockets dynamically, you're referring to whenever you add in a statement step, correct? So if you wanted 7 sockets, you would type in Parameters.ModelOptions.NumTestSockets = 7? And now you're wanting to be able to change this during runtime for the operator such that the code itself doesn't change in the background but everything is dictated by the UI?
