NI TestStand
TestStand error [1003] while testing DUT in TestStand User interface with LabVIEW runtime engine 2018
I am facing 1003 error while testing DUT in TestSTand user interface with LabVIEW run time engine 2018.But when I am testing with LabVIEW development system no error generate. Error description : Test vi is broken or contains SubVI than LabVIEW can not locate.
I have deploy Image and it contains all support  VIs and required files.
I am performing DUTs tests : Visa serial communication test and AI,DI,DO test with cDAQ 9189.
Serial communication test passed without error, DO test passed , other DO test vi generate above errors.
I have attached error description.
Please do needful.
(1,432 Views)
This error is because LV Runtime engine cannot find all subVIs.
Read this:
https://www.ni.com/docs/en-US/bundle/teststand/page/caveats-for-configuring-the-labview-adapter-t.ht...
To manage this I use Packed LIbraries. THere are other ways to handle it (search paths etc).
good luck!
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
(1,386 Views)
