TestStand Training Exercise 3-2
I'm currently working through the TestStand training and I'm getting stuck on exercise 3-2 (LabWindows/CVI), where I'm supposed to call a code module.
I used the setup.bat file to install all the relevant files, and I'm making sure that I'm pointing to the right directories; however, when I run the main sequence, I am failing the resistance test.
When I execute through the single pass option, I'm able to get the measurement result, and it's returning 0 for the thermal test and 0 for the resistance test.
It almost seems as though the test stand program is unable to read the UUT files.
Has anybody run into this issue and found a resolution?
Best,
SL
(662 Views)
I suspect you are missing an assignment of the Step.Result,Numeric assignment
Can you make sure, the code module is configured correctly for both tests?
You could as well just run the sample solution  and observe what happens there.
(644 Views)
Thank you for your input.
I've pulled the sample solution and I'm getting the same error.
The result for both tests is still showing up as 0.
Best,
SL
(633 Views)
Next guess.... what is the UUT Serial you've used?
(616 Views)
I am using the "Golden" UUT serial number.
Could it be an issue with the setup.bat file?
Based on the instructions, and stepping through the directories, none of the UUT files are stored underneath the CVI subdirectories.
However, even after copying the files into the CVI folder, the program still fails.
(608 Views)
Good point, yet I am not really sure if the CVI Version actually uses the UUT definition files from the LabVEW driver.
Do you have LabVIEW installed on your PC?
(591 Views)
