NI TestStand
TestStand Traing Issue
I've using NI learn to study teststand. Specifically "Developing Test Programs using Test Stand"
However even after completing the "Reusing Code in a Sequence" lesson the status still shows as in progress instead of completed.
I'm certain I have completed the lesson since I've watched it thrice to check if I missed anything.
Even if I am missing something is there a way to figure out what I missed?
Can anyone please me resolve this?
Linus Koli
(2,158 Views)
I ran into the same exact thing. I did not come up with a resolution. I just skipped over it to the next lesson.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,141 Views)
Is there a way to report it?
So I happened to check the webpage script of the lesson I am stuck on and compare to the script of other lessons that seem to be working.
The lesson I am stuck clearly has a different code as opposed to the other lessons.
I don't exactly have a knowledge of this but from what I can understand they have used ember js for webpage
and under the "directional__nav__button__container directional__nav__button__container--next" class they have kept "ember-view disabled" which according to me should be enabled to enable the next/proceed button which pops up the review course and exit pop-up (the entire block of code that invoke this pop-up is missing) after which you get the code completed status.
Since I the next/proceed button is disabled the course status does not update.
I am not certain about this but this is a guess. Can anyone who understands ember js have a look at it or maybe tell me a way to report the issue?
(2,136 Views)
Accepted by topic author linu95k
I am not sure how to get this resolved, However I have raised a service request, not sure if that is the right way to address this issue
(2,130 Views)
Hi linu95k
I'm having the same issue with "Reusing Code in Sequence" can't seem to get the module complete.
I have also completed the module more then once to double check if I missed something.
Did you ever get this problem resolved?
(1,961 Views)
