取消
顯示結果
搜尋替代
您的意思是:
TestStand Script automation by CLI or any other work around
I want to automate the process of Teststand script or sequence like by use of CLI or any work around.
can you please guide how can we make it possible.
0 積分
1 條訊息(共 4 條)
265 檢視
See Configuring Sequence Editor and User Interface Startup Options
https://tmesystems.net/
0 積分
2 條訊息(共 4 條)
246 檢視
You can automate TestStand sequences using the CLI by launching `SeqEdit.exe` with command-line arguments:
```bash
SeqEdit.exe /run MainSequence "C:\Path\To\YourSequence.seq"
 For advanced automation:
- Use Python + subprocess to trigger sequences
- Apply the SinglePass process model for proper execution
- Configure report plugins via `ResultProcessing.cfg` for automated output
 Helpful walkthrough: Automating Test Sequences with TestStand
This setup enables full automation without manual intervention.
Best Regards,
Thomas Batson
0 積分
3 條訊息(共 4 條)
203 檢視
Please explain what exactly you intend to do, are you looking to create and configure a Test Sequence using CLI instead of Sequence Editor?
Santhosh
Soliton Technologies
0 積分
4 條訊息(共 4 條)
195 檢視
