NI TestStand
TestStand Report is blank
I am currently running the Mobile Device Test Demo program in TestStand. I have used both the execute Test UUTs and Single Pass. The sequence file runs properly and shows the status of the steps. But unfortunately the report page is blank. I went to Configure- Result Processing and everything is enabled over there. I dont understand why my TestStand don't create a report.
(3,213 Views)
If you open a new sequence file and throw a single step in there and then run it...do you get a report?  Trying to see if something in your demo sequence file got changed.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,185 Views)
No still not getting any report.
(3,173 Views)
Accepted by topic author zakariarahman
If you go to Configure>>Station Options and look at the Execution tab.  What is set for: Disable Result Recording for All Sequences?
jigg
CTA, CLA
testeract.com
(3,168 Views)
Thank you very much. It was selected. Now i unselected it and everything works.
(3,166 Views)
