04-07-2020 07:47 AM
I am currently running the Mobile Device Test Demo program in TestStand. I have used both the execute Test UUTs and Single Pass. The sequence file runs properly and shows the status of the steps. But unfortunately the report page is blank. I went to Configure- Result Processing and everything is enabled over there. I dont understand why my TestStand don't create a report.
04-07-2020 09:14 AM
If you open a new sequence file and throw a single step in there and then run it...do you get a report? Trying to see if something in your demo sequence file got changed.
04-07-2020 03:32 PM
No still not getting any report.
04-07-2020 04:09 PM
If you go to Configure>>Station Options and look at the Execution tab. What is set for: Disable Result Recording for All Sequences?
04-07-2020 04:12 PM
Thank you very much. It was selected. Now i unselected it and everything works.
