TestStand Numeric Format
I have two questions regarding numeric format and precision in TS.
1) I have the format, in report options, set to %.13g. When I return a 0 into TS, TS displays "0" in the report. Is there a way to set this "0" to "0.000..." ?
2) Also, if a function returns a value like .020 seconds. Is there a way to display this in the report as "20" and then I can set the units to "ms"?
(5,566 Views)
1) The format you want is "%#0.13g"
2) It doesn't look like TestStand supports SI notation.  That would be really cool if it did though.
(5,562 Views)
So, for your (1) recommendation...would this effect the precision for other actual values display if I change it to "%#0.13g" ?
(5,552 Views)
I'm not sure what you are asking here.  When you set a format for changing to a string or a display, it is only good for that one setting.  The "#0" just says to fill with 0s.
(5,545 Views)
