NI TestStand
TestStand Error only when using Operator Interface
Hi Ray,
I believe the error happened whether the seqEditor was running or not.
Billy
Message 11 of 13
(1,100 Views)
Hi Billy,
To repeat Ray's question from earlier, have you / can you try the unmodified SimpleOI or use the Default OI?
Mark E.
Message 12 of 13
(1,079 Views)
Hi Mark,
No.  Because as I mentioned earlier, we fixed the problem by adding another TestStand Step, manually entering the parameters, and deleting the original Step.  We had heard from someone that copying TestStand Steps didn't always work.  I don't know why it works directly in TestStand but not when running from the OI.  I just know it works after that change.  The test set is now being used in production and I'm still curious about this problem, but I have to move on.  Thanks for your help.
Billy
Message 13 of 13
(1,075 Views)
