 bwv1043
			bwv1043
			11-23-2010 08:47 AM
I'm currently using TestStand 4.2.1 and recently received email about 2010 release. I read 4.2.1 bug list here http://zone.ni.com/devzone/cda/tut/p/id/8681#172793_by_Category but was wondering if any of them got fixed in 2010.
Is there a list of Deployment Utility bug fixes included in TS 2010?
Would you recommend upgrading from TS 4.2.1 to 2010 if I have run into issues with Deployment Utility? Most of my issues have been posted on forum but many without clear solution.
Solved! Go to Solution.
 Tanya_V
			Tanya_V
			11-24-2010 10:56 AM
Hi hellochicago,
I've attached an HTML version of the TestStand 2010 Readme file. This includes the list of bug fixes for this version.
As another note, the Deployment Utility has been highly improved in TestStand 2010, so I would recommend upgrading regardless.
I hope this helps!
11-24-2010 11:32 AM
Thank you very much for the list.
11-30-2010 12:48 PM
I upgraded to TS 2010 and all problems related to DU have been resolved. I was able to successfully deploy TS with default UI, process model with minor modification, LV 2010 test code and a DLL which I developed in CVI 2009 SP1.
