NI TestStand
TestStand Database Viewer
Recently, one of our test engineers returned from one of our contract manufacturers.  Before he left I asked him to bring back the datalog files.  To my surprise the files were all .mdb or database files.  My hope was columnar data.  Is there a way to convert the .mdb files into .dat or .txt files?  I work exclusively in Excel to crunch data.  My tools are all in Excel.
(3,317 Views)
Hi Tony,
I have not tested this, but within TestStand go to the Tools menu and look for "Database Viewer."  I believe within this utility you can open your .mdb file by going to File>>Open.  After your file is open, you should be able to go to File>>Export Document which will give you options to export the data to a different file type such as .txt or .csv (even xls or xlsx).
Adam
(3,267 Views)
You can open the Microsoft Access MDB database file directly in Excel.
Specifically, In Excel click on the “Open“ button. Select to find any file in the file types. Locate the .mdb file on your hard drive. Select the file. In the prompt, select the table from the database you want to add to Excel and double-click it. Select how you want to import the data in your workbook (typically, the “Table“ option is selected). Click on the “OK“ button.
Scott Richardson
https://testeract.com
(3,251 Views)
