NI TestStand
TestStand 2016 Determine FileGlobal Type Programmically
I have my FileGlobals test parameters stored in a 3rd party software package as string elements (company thing). When I read the information from this package, I need to determine if the data should be stored in the FileGlobals as an Integer, Float, Boolean, String, etc. so that I can call the correct TestStand API, such as FileGlobals.SetValNumber(...), etc.  I am trying to determine if there is a TestStand API which will allow the specification of the FileGlobals parameter and the function will return the data type similar to the FileGlobals.Get*() whatever APIs.
Thank you for any help.
(2,617 Views)
Accepted by topic author Bill.Simmons
You could do something like this and then case off the name.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,588 Views)
Thank you for your help. You pointed me in the correct direction. After a little trial and error, I found a more direct solution.
Locals.FileGlobals_Element_Data_Type = FileGlobals.GetPropertyObject( Locals.FileGlobals_Element_Name, 0 ).Type.DisplayString
After I have the DisplayString, I put a precondition, based on the DisplayString, on the steps that convert and set each element from the input string. Now that I understand that method, I will now try to determine if a Number is float, signed, or unsigned, etc.
Thank you again !
(2,580 Views)
