Test sequence parameter default flag setting
is there a way to test in a subsequence if a passed parameter has been set to default in the calling sequence.
(3,646 Views)
Accepted by PG6272
Yes that is possible,
Try to use  RunState.CallingStep.TS.SData.ActualArgs
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,635 Views)
Thanks Juergen.
The solution is indeed to check the boolean variable RunState.CallingStep.TS.SData.ActualArgs.<Parameter name>.UseDef.
(3,631 Views)
