NI TestStand
Test Stand and MAX Settings
I am using test stand and Labview 7.1.  I used Express VIs to setup my RS232 communications in numerous VIs that I call from test stand for different types of tests.  I have the same product, but with different baud rates.  Is there a way in test stand to change the baud rate settings in MAX for Com1?  I tried to create a Labview program to do it, but once a sequence runs that has the Express VI I/O Control it must start a new VISA session and I loose what was set up and it reverts back to the MAX settings for Com1.  The only time The VISA setup vi I created appears to work is when I converted an Express VI (or opened the Express VI's front panel).  And messed with the code.
(3,481 Views)
What do you mean "And messed with the code"?
Regards
Ray Farmer
Regards
Ray Farmer
(3,473 Views)
I just added a constant for the Visa input (Com1) and set a couple strings I wanted set.
(3,467 Views)
Hey,
I would suggest using the VISA Configure Serial Port to configure the port and then calling the Express VI using the VISA Resource Name Out from the configure VI.
Regard,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,451 Views)
Oops!  Here's the 7.1 version.
jigg
CTA, CLA
testeract.com
(3,449 Views)
