Terminate Using ProcessModelPostStepFailure within batch model
How can you terminate execution using the ProcessModelPostStepFailure callback.  It works in a sequential model, but the same API call to terminate using runstate.exection does not.
(3,583 Views)
Hey trussel,
I got it to work by doing the following-
1- Open a new blank sequence file
2- Open the SequentialModel.seq file by double clicking on the link at the bottom of the sequence editor
3- Click on Edit at the top of the sequence editor and go to <b>Sequence File Callbacks...</b>
4- Click on the ProcessModelPostStepFailure step and click Add
5- Click on the Edit button on the dialog box
6- Add an ActiveX action step
7- Right click on the new step and go to <b>Specify Module</b>
8- Set the settings as the following-
     Object Reference = Runstate.Execution
      Automation Server = NI TestStand API
     Object Class = Execution
     Action = Call Method
     Method = Terminate
9- Click OK
10- Go to the new sequence file in Step 1 and add a pass/fail test
11- Right click on the pass/fail test and select <b>Edit Limits</b>
12- Change the lower limit to 5 and select OK.  (this will make the test fail since it is comparing with 0)
13- Run the sequence by going to execute>>Single Pass (don't save the files)
You should see that the execution terminated correctly.
I hope this helps and is what you are looking for.  Let me know if there's any other info. regarding this issue.
jigg
CTA, CLA
testeract.com
(3,562 Views)
Thanks for your reply Sam,
I think your example is within the sequential model.  If you use the same callback in the batch model the program will not terminate.  What I'm doing is creating a custom process model that will loop a test on a DUT.  If the DUT fails, then I want to terminate the batch test.  If it passes, then I want the loop again.  We will be using this for HALT testing in a temp/vib chamber.
I have a work around for it though.  In the sequential process model, the termination status is checked and will post a dialog prompt to terminate the test.  The batch model does not have this.  So what I did was evalute the terminate status in the batch model, and then I put a post action to exit out of the batch loop. Not sure if this is the preferred method, but it seems to do the job.
(3,557 Views)
