NI TestStand
System Level Exception, error -17502 when running VI with RunTime Engine
My sequence conains a single Labview VI.  The sequence functions correctly with the Labview RunTime engine NOT selected in the "Advanced Setttings" tab.  When I enable the check box to always run the VI with the Runtime Engine, TestStand generates the following error "System Level Exception, error -17502.  My teststand version is 3.5, with LV 8.2.
Peter V.
(3,791 Views)
Are you sure you have LV 8.2 RTE on your system?
Regards
Ray Farmer
Regards
Ray Farmer
(3,785 Views)
Yes, it is installed.  At first I was not sure, so I downloaded the 8.2 RTE and tried installing it.  The installation was terminated as the indication was that it was already installed.
Peter V.
(3,780 Views)
Hey Peter,
Would it be possible to post a screenshot of the error message as well as the example sequence you are running?
Pat P.
Software Engineer
(3,763 Views)
